There's some people on ebay selling 'genuine' ones for around £600.
But who knows, I'd rather buy from an arbtalker if poss.
I could even offer my old foot-spa in part exchange.
You're a GOOD LAD SHANE HONDA MAKE THE BEST FOOT SPA!!!
All the best, CIZZER, etc, etc....
  • Replies 31
Loncin G420 replaces the GX390 , also comes with electric start as standard .
Good quality Chinese engine , Loncin is fitted by many O.E.M'S now inc BMW ! our experience with them on ALKO lawnmowers has been faultless , in my opinion are better than Honda as they do not seem to suffer from the carb issues that Hondas do .
P.m me if interested I will be happy to quote
Sent from my iPhone using Tapatalk
Hi Neil I'm after a v twin 23hp with a bit of a weird spec are you an engine dealer?
When i recently had to have the piston rings changed on my GX390 the mower mechanic was also praising Chinese engines as a replacement which did surprise me. I'll certainly be looking in to it when it needs changing.
Sounds interesting - what are trhe spares like for availability and cost?
If it comes with leccy start do I need to find my own battery or does it come with some ither magic elctricity storage system of which I know nowt?
Secondly, do they do a bigger engine with the same shaft output and a similar 'footprint' for easy mounting?
As you can see I don't want much.
My wee grinder is fitted with greenteeth so I'd love to give it a bit more oomph while I'm at it - but I don't want to over complicate things.
Only got a Loncin in my Snowblower, starts fine, runs instable in idle from new, has carb issues after 4 years but does it's job as long as I don't forget to close the gas tap.
For the price I think, one gets what one pays.
Not sure how they hold up in a stump grinder, which have a much harder life than mowers and snowblowers.
Ever thought about replacing the 390 with a Kohler Command Pro?
Reasonable prices and pro-grade.
Same mounting pattern as the Honda, better airfiltration-system imho, very important in stumpys.
If the engine makes a part of my living, I would not save on the wrong end.
MOTORE 4T BENZINA 14 HP KOHLER albero cilindrico da 25,4mm CH440 by LOMBARDINI | eBay
We have several Hayter Condors waiting to break, we sell a good used GX340 11hp model for £225 inc vat, inch parallel crankshaft. Generally these engines havent had a hard life, no concrete dust. Generator engines will have a tapered crank as mentioned. Dont know will 11hp be enough but physically the same size
Thanks Harry. I think I'll hold out for a 13hp option, there is no urgency really so I'll look around. My local supplier has also suggested Loncin as a possibility - recons the carbs are the only problem, and you can get a new one cheap or even use the one off the Honda engine.. Time to get thinking.
I have a genuine Honda GX 390 you could have ( for the right price ) Not done much work . Have sent you PM Shane . :001_smile:
Shane you will need to supply your own battery , a decent small sealed one will do just fine.
Spare parts are sensibly priced and are backed up in the uk by E P Barrus , I also have another supplier in Germany who has large stocks of common Loncin parts .
Next size up from the 420 is a v twin 19.7 Hp 22hp gross this is electric start ,very similar to a gx670 but much cheaper .
