MK1 they will replace regardless of if its broken. Don't quote me on it but i believe they will replace even without a receipt, you might have to contact Lyon the distributor direct though.
Ok thanks for that steve
  • Replies 79
Why do people buy these sort of things when all it seems to replace is a Prussik loop? The traditional being cheaper and likely more reliable?
Sore elbows is one reason I think .
A traditional prussik you are climbing ' one-sided' so to speak . When using a device like the zig zag you climb hand over hand symmetrical with your body . Theoretically this should be easier on your limbs ..
The zigzag is a brilliant device, my climbing has definitely benefited from its use. Slack tending and small adjustments is great.
Same here, I'm glad that I learned on a prussic and blakes etc. Because it helped me learn about ropes and knots. I wouldn't go back to using it on a daily basis though, because I love my Zigzag too much.
A horse is a good way of getting about but a four wheel drive is even better....if you know what i mean....ZigZag simplifies and improves everything...even on wet rope.
