It is confusing!
Sugihara is one company that makes guidebars in Japan (although their actual factory name is Diatop) and Sugihara is the brand name for their bars.
Tsumura is another totally seperate company in Japan that also makes guide bars (their company is called Suehiro Seiko).
Both companies have a reputation for making an excellent product.
I think that some of the Echo 2510s now do come with 1/4" drive sprocket as standard running a Tsumura small tipped carving bar. Tsumura do not make a sprocket nose bar to run 1/4 .043 chain (nor do they have to tooling to do so at the moment).
If newer versions are running a 1/4 .043 sprocket nose bar these will be Sugihara bars - who do make a 1/4 .043 sprocket nose bar but it will not run the Stihl 1/4 .043 chain (it will run Sugihara's own version of the 1/4 .043 chain).
Tsumura seem to make the laminated bars on the smaller Echo saws while Sugihara make the larger pro solid bars on the larger Echos.
Cheers Rob, I'll share the bottle with you :thumbup:
Thanks Rob D.
So you'll be needing my address then :biggrin:
Mine was 1/4 pitch and came with this fancy bar which I believe is a sugihara pro lite carving bar in 1/4 .50 but was swiftly swapped for the stihl gear as it cuts better. Shame as it did look good with it on
