It does look, upon closer inspection, that it's a complete crankcase replacement. No easy fix by the looks!
if you are mechanically inclined there is nothing to replacing the cases your self. Just be careful not to stress the new bearings installing the crank. Also a good time to replace the crankcase stuffers that sit on the crank. These wear and are not expensive.
  • Replies 36
That's a good call on the stuffers . Not unheard of for them to come loose and cause a bit of a catastrophe :001_smile:
yep 100% it must have been a 560 block unless he has built his own 550 block but he would of had to do this with parts himself
I could of sworn it was a 550 block he had on the desk that prompted me to ask but your probably right then!
