full chiesel chain????
pete23
afternoon all.
I have a load of old gnarly cr=p that my splitter wont split.
I been told a full chisel is the way to go for sawing into smaller pieces, is this correct??
me biggest saw is a 036 on a 18" bar, will that pull a chain of that nature??
best reasonable priced place to get one from??
your thoughts??? and thank you.
Chisel - Also referred to as “Flat Top” or “Square Corner”. Best when used in clean cutting conditions and is a fast cutting chain. This chain will dull quicker if the cutting corner is exposed to dirt or abrasive conditions and takes a little more effort to sharpen properly.
• Semi-Chisel - Also referred to as “Round Tooth” and “Barrel Tooth”. This chain may be a little more forgiving in dirty situations. Many find it easier to file due it’s rounded edge.
