Pretty new to milling , but landed a common walnut job for this week . Milled a couple of pieces at 2.5 inches thick which cracked almost straight away . Is this normal for walnut ? Should it be milled thicker to avoid this ?
Hi I am not surewhat the prob could be as walnut is a very stable timber was it a very hot day and thebut very green is the only thing I can think , paint the ends with p v a glue as soon as milled will help , sorry cant be any bigger help , good luck with the rest
Cheers Mark
The second comment suggests that this may be a branch? If so, which way round you mill it will have a big bearing on balancing stresses.
Alec
Some pics would help identify what the cause of the cracking is but could be tension in the log or shake... over zealous wedging would not cause this.
