  • Replies 37
For vertical welding hold the rod at about 45 degree, tip pointing up,work downhill and try to draw a very fine figure of 8 across the joint not along it
Upwards or downwards are both possible but much harder than overhead or flat. Downwards produces a thinner bead, use a higher current a go fairly quick to keep ahead of the slag, which tends to drown the arc,
Upwards use as lower current as you can strike, get the tip doing a triangular dance, one side, the other side, then round the front as if to blow the bead back up hill and into the corner. Very much harder to make it look pretty but if you cant get the job flat then it has to be done.
