I dont know how you can mull stuff over for so long John.
If i want something i do some research yes and have a good think, but the more i think and the more stuff i look at it fries my brain and you find yourself overlooking at things.
Pick something, buy it and be happy :)
Hi MATE been they're done in the past just waiting bought things all the wrong stuff are no good so I'm asking what's the best traitor know I think I know thanks John
Interesting points regarding the tri axle trailers Jon so don't discount them. Oil be buying a tipper trailer next year and will try and pick up an older ifor 10' X 5'6'' as they are well proven compared to the newer ifor models, if not oil buy a Brian James.
  • 2 years later...
2 minutes ago, ostosix said:
how often do you use the 3 way tip? Whats it like fully loaded?
I use it all the time. Takes about 1 minute to alter the tipping function. I have cages on it and if I have green I tip to the right as it suits the layout of my local recycling centre and also reduces it getting stuck if it's packed in tight cos of the cage.
Tips absolutely perfectly at full capacity. If I'm loading with dirt though I always barrow 1 ft away from the front end and pile it up more middle in case it wont fully tip if occidentally go over weight. However, if that ever happened you could go side tip to shift weight off it and then rear tip or various options.
3 way tip was always just a potential convenience to me but has turned out to be used all the time in various ways.
Solid bit of kit too. Some prick lowered my jockey wheel in the night one day and I drove 7 miles with it full down and it only bent ever so slightly.
