The three shoe clutch was far too heavy and not needed for the smaller saw, so the two shoe, clam shell spring clutch ( as per 346 ) was fitted
  • Replies 55
When you jar the clutch off against compression you are not exerting a direct force on the internal components, when you insert somthing into the cylinder to lock the engine, and then use a socket or such to remove the clutch, you are now exerting a direct force onto the piston crown, connecting rod, cylinder head etc, which cannot ever be good practice.
And yet, Stihl recommend a piston stop on their saws and say never to use an impact wrench.
I must admit though that I never use a stop, sometimes use the starter cord method and invariably use an impact gun. But NEVER use a piston stop of any sort and an impact gun together.
I certainly did not know that
That all makes sense, at least with the ms261 a standard socket fits and it is so quick compared with taking the spark plug out. I can see an impact gun and a piston stop ending up with a lot of damage.
As already has been said - there is no need to complicate this with special tools or piston stops - a sharp blow on a suitable chisel/drift/screwdriver is all it takes.
That's not always the case though.. But it's great when they do!
