Not to derail but since this thread is full of nightmare jobs I thought I would ask how good are the carbide rescue blades, carbide cluster blades, carbide chunk blades, rippa blades, terrasaur blades (see who knew they could have so many names?)
I might need one for that wall job I think, if its going to work
Good longevity? Worth the investment?
One thing about having a reputation for doing the worst stumps is they just keep getting worse!
My record for bricks in a stump, it ended up being close to 30 all up! Tree must have grown up through and eveloped a pile of em. So long brand new set of greenteeth
Edited by Timbermcpherson
That is such a great idea with the wooden wheels, well done!
My grinder needs to be a bit narrower for this one. Ledge is about 350mm wide with the stumps in a 100mm gap and 2m up a wall. and there are at least 7 of them to grind.
the pen gives an idea of scale, the electrical cable is the icing on the cake for this one!
I've just checked my quotation procedure, and that one came up with 'someone else's problem'....
Wheres the fun in leaving them?
Someone screwed up royal in leaving that gap in contruction as the pohutakawa roots have penetrated through stuff underneath, causing leaks in the 2 stories below. They have to be ground down 100mm so gap can be capped off.
Fair enough, what machine are you going to use?
