  • Replies 25
no, 9ft wide 4ft high,
I dont know if they do small quantities, but as an example I had a 1.5m high by 6 m long panel at under £250 This was 100 mill thick but they make them thicker for thrust, mine only have chip or cattle
hollow will be easier to concrete as when you try and fill a cavity the concrete can push the blocks apart even when wall ties are fitted and you would have to build the wall 4 or 5 coarses at a time then fill a day or so later the other way would be to set up shuttering with mesh in between and cast your own wall
if you cant help please dont comment ,
its NOT a supporting wall ,its going between 2, containers do try & think outside the box ,:001_smile:
Hi Johnny why not use railway sleepers to make a wall that one and use RS J into ground and then Bridget with railway sleepers thanks John
