  • Replies 36
Be very carefull and don't forget to protect yourself.
[ATTACH]177909[/ATTACH]
They are the most god awfull things to wear and un comfy to boot
The big ones usually do as they are told, its the smaller ones that tend to go bang. The main thing is forget the NPTC rules on the size of your gob, go where the sound wood is, if that means a tiny gob then so be it, if it means a massive one then do it. Don't worry about the wood in the centre, just try and get some live wood at either side, don't leave it too thick either, 15% max, it will go with the lean so fell it that way..
In this vid I was felling some biggish crack willows, they were 80-90 foot. The only thing I'd say is don't lean over the back of the tree (as I do ) when checking your cuts as if it goes like Matty's did you could get a sore chin....
[ame]
[/ame]
If it's leaning in the right direction you don't need directional control, it's not directional felling as such, you are aiming to release the tree to its lean as safely as possible.
Don't leave too thick a hinge, it may barber chair. Other than that, as Tom says assess every tree on its own merits.
Here's a particularly ugly customer I dispatched last year.
