Dan, how can you borrow a load of firewood?
What sort of condition do you return it in?
It's returned in the form of lovely sopping wet cord, stacked and ready to process. :P
  • Replies 45
French friends cut oak for firewood from managed woodlands. They say it's no good unless it's seasoned for at least 2 years. It's split, stacked and left totally unprotected for the first year. The weathering does 2 things - the wood starts to twist and open up and the rain washes out the tannin in the oak. Both apparently essential for a good burn. Yr 2 top of stack covered over and then moved later on into the woodshed.
Voila, c'est simple
Voila, c'est simple
Yep pretty much what I do
I've found you can significantly speed up the drying time for oak if you split it into small logs - six months I'd say.
As a general thing that is also very good for increased flame patterns and easy heat output, just does not last more than about 35 mins in the firebox.
A
Burning a mixture of Oak, Ash and Sitka at the moment. The Oak has been cut to 10" lengths and split and air dried for 2 years. It burns very easily, very hot and leaves a great bed of embers.
I don't tend to use it on its own. It works really well in the range cooker and the outdoor brick oven - superb for roasting meat and making pizzas.
