The cost of going bigger?
Will C
I know these aren't accurate but
3.5 t, vehicle weight with box on and equipment and guys - 1.5-2 ton so that leaves you with 1 ton to play with. I'm not sure if chipper is included in that.
7.5t vehicle with equip and men + hiab - 3.5 ton so you have 4 ton to play with and no heavy lifting/ringing up and all that sawdust.
Most 7.5t trucks have a payload of around three and half ton, add a hiab then throw the rest of your gear and two/ three blokes in, you'd be lucky to get two ton on it.
  • Replies 55
The cost of an HGV license ,a bigger truck and a crane will give you a return on the investment a lot quicker than you think. Just add up all the mind numbing trips you make in a small truck to clear up one decent size tree, in a transit thats a ton a trip, even a little eighteen tonner will carry ten transit loads. Take the fuel and man hours saved and the bigger trucks start to look like value for money
Bob
3.5t vans are crap for tree work, i have being granted an operators licence but have hung off buying a wagon as i have bought a new chipper. Their is pros and cons to going hgv the big plus is the fact that you may only have to tip off once instead of 3 and 4 times! I paid for a firm to get my o licence as i didn't want the hassle all in all cost about a grand. Inspections are not much bother with a mobile mechanic. For us i would end up running a 3.5 tipper along side to quote / when we go fencing and sell my fiesta that i use now. Also i would have to park the wagon at the yard which means dragging all the gear down their everyday. You can get an Isuzu grafter that can legally tow 3.5t no o licence , park where you want, no inspections etc. this has thrown a spanner in the works hgv or no hgv???
I've had my truck 1 day. Played with it on a small job where it halved the time on task then went and collected a shipping container and lifted over the wall onto the lawn next to the door ready for moving house on Friday. I also picked up 2 timber moving jobs ( just need to work out price per mile and daily rate). All in all awesome, I haven't even put a tipper on it yet or filled it with empty come bottles.
However, I did get stuck and that water a lot of time, but you can't blame that on the truck!
Payload on a 3.5t would be less with nose weight of chipper/trailer deffo under 1 tonne with fuel men tools, a 7.5t Mitsubishi fuso has a payload of 4 tonnes, if you want a hiab your better off going 10 tonner as the weight of a crane on anything smaller will kill its payload.
No, not accurate so pointless. The very lightest 7.5t trucks come in with a 4t payload if you're lucky and that's without guys in them. A hiab will be close to a ton so your real legal payload would probably be closer to 2000kg. However a 10t lorry has more or less the same footprint of 7.5 and would have the payload still...further more an 18t as myself and few other members run is a little bigger but had a huge payload even with a large hiab fitted. Also a 7.5t and trailer only requires C1+E which is much easier to come by than C+E
What truck you got?
