Ford ranger, lack of power when towing and a screeching noise too?
While towing a Bandit chipper yesterday the truck was low on grunt when going up hill, and there was a screech/slipping sound coming from the engine bay.
Its an '06 2.5 TD Ranger and hasn't done a lot of towing in the time I've had it, not sure about previous owners:blushing:
Any ideas on what it could be? :confused1:
Thanks in advance:001_smile:
  • Replies 28
When did you last have it serviced? Although it sounds like the turbo, the noise isn't.
I'd check the oils too - gear box, transfer, front and rear diffs etc. I had a landcruiser that only did it in reverse :blushing:
Check the inlet and exhaust manifolds - I've had the exhaust manifold go twice on mine near the back of the engine and it screeches just like slipping belts. The power issue might just be that you are towing a really heavy chipper!...
