  • Replies 22
I asked this same question last year and got a load of flannel and bs from the "man up brigade" and made to feel like a prize t$£t for asking.
I was cutting somewhere in the region of 150, 20-30"dbh windblown ash trees that caked the chain and the top of the cutter plate so badly it was like using a blunt chain, making it annoying at best and dangerous when needing to zip through and make a quick sever on some of the stems.
I think most will think you are either OCD or a newbie trying to keep your kit shiny and well maintained (more fool you) and not looking at this from a practical level. Worse yet, you will get told to learn to sharpen your saw :sneaky2:.
I found that a scrape of the cutter plate while sharpening, bar oil to max and if poss some lengths of other timber to clean up with, a bit of noodleing will help..... a little.
I asked this same question last year and got a load of flannel and bs from the "man up brigade" and made to feel like a prize t for asking.
Yea thats all very well Normandy but COME ON YOU QUINS ! :biggrin:
When I learnt all the saw maintenance carry on I remember being told to use a wire brush if the chain needed cleaning, never done it myself and as others say cut something else and if the chain is that bad should you be using it?
Only chain's I ever cleaned, were cycle and motor cycle chains. And only if I'd been riding through gritty mud or water filled ditches or all day in dust. Put chain in old saucepan with parafin and bring to boil, then simmer for as long as I dared. Then drip-dry chain and finally soak in warmed chain oil overnight. Then back on the bike or wrapped in oil paper and back in spares box.
Edited by TGB
I've always found that chains only end up blackened like has been described when they are being used dull and forced through timber. The extra friction causes the fine dust from a dull chain to mix with the oil and harden onto the cutter plates with the heat.
A good sharpen, and some clean timber should clean the chain. Failing that, put them in a sandwich bag with some WD40. I only oil my chains if I've sharpened them and plan to hang them up for a while before use.
I have found that cutting ash or oak leaves deposits on top of the cutters, but not to the extent that Normandy describes. If it's excessive then you need to assess your sharpening, this could be anything from the chrome left when sharpening sitting slightly upward, depth gauge (take it down to .30 as opposed to .25), filing angle (25 deg in hardwoods) and any chips or dings on the cutter. Also turn the oiler to full!
I've soaked mine in petrol or diesel overnight then cleaned them with a wire brush wheel on a bench grinder. Often times the chains aren't that dull it's just that there caked in sap and resin. A bit more work but less time spent sharpening is always good. Not a job for a week night of course, nothing like a Saturday evening sharpening chains in the workshop! :thumbup:
