  • Replies 59
Are you made of sugar sweetheart? You're not gonna dissolve!
Always happy to prove you right Bolam.
FWIW the cut and climb is ace, and I find hoods cumbersome so I don't mind not having one.
They are Joe, but when it's really hosing it down it will eventually get down your neck and soak your One Direction tshirt.
Mind, I'm told you wear a Stetson at work, so you'll probably be ok.
I'm having a go at a navey gore tex jacket surplus army coats brand new found it on eBay think it was only £35 they are fairly long so won't be that good for climbing but a brilliant groundsman coat worth a look
Yeah i'm not after an expensive one because i'm not working everyday but cheers ill have a look now
No offence but if you buy cheap you buy twice in my opinion. the cut and climb jacket if very, very hard wearing and waterproof, does not need re proofing and is machine washable.
Sorry it's RAF
I use a Regatta jacket of some sort. Served me well over past couple of years, still waterproof and a lot cheaper than other makes
