Hello every one been a while since I was last on I've been using my Stihl 051 AV for home use and its been running great but has now decided to play up while half way cutting my logs up so I have decided to purchase a second saw for back up purposes.
The spec for the new saw.
It will only be used for my own personal use for cutting logs for my fire wood so for instance once maybe twice a month but will be run all that day.
It will need to be able to cut through logs up to 24".
It needs to be pretty reliable/well constructed and have a good reputation.
Any advice is much appreciated.
Thank you .
  • Replies 63
I know second hand is always a risk but if you could find a pre Xtorque Husqvarna 372 then that would be my choice . I have a 2003 model still going strong as you like.
Hi
365 good choice solid reliable saw with no gimmicks, I run 20" on mine but they can go to 24 its an excellent saw. Also easy to increase power if desired.
N
