Howdoo
New to this, currently a one man band with a small customer base , i currently deliver from the back of a Ford Ranger (crew cab) with a truckman type top.
Loading up is me handballing in, but looking for a quicker and simpler way of unloading, ie roller system on rear bed, there are a couple of systems out there but not compatible with a truckman top
Want to keep the top.
Any ideas???
Cheers:001_smile:
  • Replies 25
Howdoo
Any ideas???
Cheers:001_smile:
I do exactly the same with exactly the same vehicle (and before you say it Mark, no we don't share it). I like the canopy on as it keeps the stock dry, I can leave it parked overnight outside the house with a full load on knowing it is secure'ish and dry, and I used the pick up for other uses so the canopy is useful. I used to put a tarpaulin down in the rear before loading and then when had small amount left in I could just pull them out but that did not last long. The loadhandlers sit on the tailgate so would interfere with top tailgate so they would not work. Short of a walking floor or having rear converted to tipper using existing rear body I think we are stuck hand balling them out.
Couple of dumpy bags laid flat in the bed can be used to drag the bulk of the load out. Last a lot longer than a tarp and have handles... handy
Can you not use a Loadhandler?
If it fouls the canopy can you just take it off the tailgate and tuck it inside and just strap it back on when you open the tailgate. May be a bit of a fiddle but probably still quicker than handballing them all out.
