Best 14" saw for cutting cordwood?
Husky kid
What would actually burn out the MS180? Would it be the duty time cutting up a large amount of wood, or the thickness of the logs being cut? I have a large amount of cordwood to cut up (Leylandii) with my MS211 - I wouldn't have considered that I would burn it out doing the job.
It wouldn't burn it out. The only thing to take into consideration is whether it's worth your time sitting there with a small saw- possibly not, when a larger saw is not much more money.
Full chisel chain won't make much difference if any on a 181. With a properly sharpened semi chisel chain my 181 is always on the cusp of bogging down- there's just not the power there.
What will make a difference is changing to a thinner kerf- a 1.1mm bar and chain.
  • Replies 27
I wouldn't advise anyone to buy a semi-pro saw or a hobby saw, a complete waste of time and money. Spend the extra bit of money and you'll reap the rewards for Years to come. I buy and run only pro saws because their built to work all Day and will if properly maintained last for Years. Even if you only use a saw every now and again I'd advise the purchase of a pro saw. For firewood I'd recommend the fantastic Stihl MS241 C-M with a 16'' bar which I own. Other options would be either the Stihl MS261 C-M or a Husky 550XP with an 18'' bar.
Happy cutting:thumbup:
Am I the only 1 that finds the 346 a bit of a heavy munter??
To be fair I had the xpg which is heavier and didn't find it anything special even with a muffler mod.
With the 346 on semi chisel against an ms250 with muffler mod and full chisel I used to grab the stihl every time as it was quicker cutting and lighter to.
I much prefer the 357.
