13 hours ago, monkeybusiness said:
If it needs a different rear diff ratio surely it will also need a different front diff ratio too?... Sounds like it could quickly become expensive...
good point,  yep yer into big money there.
I checked with SV Tech. It's only the rear axle assembly that's required. It is infact only the internals of the diff, but it's generally cheaper to get a new rear axle. A new one is £800-1000 plus labour, less for a second hand one.
Sounds incredibly cheap for a new rear axle - bargain!
I'm only relaying what I was told. I haven't verified the price.
amazed the front diff doesn't need to be swapped out too as i assumed it would suffer from transmission wind up?
It would on old school 4wd systems with centre diff locks, most modern 4wd vehicles use traction control systems ( brake grabs a spinning wheel) so there is no need for centre diff locks. The only thing that would change with a taller diff one end is the torque bias.
Bob
Bob
What he said :D
On 06/02/2020 at 20:10, Big J said:
Incase anyone is interested, my very lovely 2012 4x4 Sprinter is on eBay now. I'm just not using it, so it's for sale. You'll not find a better example, and studies have shown that such a vehicle makes you at least 34% more manly ?
If I could raise the money in time that's just what I need, great truck
Happened across this photo yesterday, around 99/00, after the Ford P100 I bought this, the first of two red Hiluxs, this one is the non turbo, bit gutless by today’s standards.
Vanity plate and BFGs, I’d really arrived!
Edited by Mick Dempsey
  • Like 13
