11 minutes ago, josharb87 said:
My two, the van arrived today :)
IMG_4112.thumb.JPG.ad831f4236499f8fa6b128a646e964bb.JPGIMG_3564.thumb.JPG.583d6a95985307382694b70c7a0a0e4d.JPG
Is that a 12x6 Josh? How do you find the trailer? Is it the newer style with an ally floor?
Will be looking into a 10x5 for extra capacity on jobs soon.
Been offered my mates 12x6 but its old style and weighs 1300kg empty he says. Thats before i put sides on it :P
Yeah it's the new style 12x6, TT3621 I think it's now called. Mines about 1300kg with the sides I think (they're actually the mesh sides with 3mm chequre plate bolted inside so weigh a little extra. And the steel ramps weigh a ton! The ally ones are far far better for regular use.
I think it's great, no problems with build quality or performance.
I put a small dent on the ally floor when I loaded a 3.5m long ash stem with the avant and dropped it maybe 10-20cm so it's still pretty tough even if ally!
8m3 capacity is really useful too
@swinny
The TT3621 is a big trailer to get into some drive ways were as the TT3017 is easier and came be loaded with more as unladen weight is less.
Ive even considered an 8-5 but bot sure if too small to be honest.
Agreed. I have a 3017 as its the same width as a pickup, with the standard high sides it holds 7m3 which is about right weight wise for chip (approx 2-2.5t) and is still wide enough internally for most mini diggers/grinders/tracked chippers.
Out of interest, how’d you work out 7m3? Just curious as i work it out at less than 6m3 if same height sides as mine :)
valid point though, the 3621 is a good size, but only the same width as a Toyota dyna twin wheel tipper.
Sweden is far more spacious than the UK so I’ve never had a problem with the size, the m3 capacity is perfect for my work, smaller just wouldn’t work.
