How do u get on with that pickup? Chip capacity wise? Looking at a single cab l200/hilux you see
It doesn't hold loads but for the average job it's fine, it handles the weight fine also, it's a compromise for having a 4x4 for sure but i can live with it. A good network of chip sites helps!! ImageUploadedByArbtalk1443915784.411156.jpg.497995312cba1520860cc640cf136671.jpg
It doesn't hold loads but for the average job it's fine, it handles the weight fine also, it's a compromise for having a 4x4 for sure but i can live with it. A good network of chip sites helps!! [ATTACH]190987[/ATTACH][ATTACH]190988[/ATTACH]
What can you get in there, about 3 cube? It'll be a reasonable size for many domestic jobs.
As a "tip", literally, if you're using that shovel to empty with, try a much fork, one from a farm hardware shop. You'll empty that thing in half the time. 👍
A potato fork is also a good one.
Yer about 3 cube. Cheers for the tip I'll try it cheers. It takes 4 minutes to empty it with the shovel.
Yea fair enough pal, if you can get all that on a double cab, a single cab would take a bit more yea? Cheers for the reply mate 👍🏾
