  • Replies 51
beech wont last very long tho as fencing material...shame would make some nice indoor pieces
Sent from my GT-I8160 using Tapatalk 2
Yep, bit of a waste of time building a fence out of it..... better to save for internal projects or those protected from the elements.
Unfortunately i am only the milling man the timber is not mine, but never the less it is learning me what I can and cannot do, thank you all.
If u r the milling man, then its ur expertise that shud be guiding your client. Beech is useless outside and will be a waste of your time and presume their money.
Better off as firewood for the bunk house.
That bad boy would keep your house nice and warm. Good piece to practice on rather than a nice piece of oak. If it goes a pear shaped it will still have a use.
Fencing or outside use is ridicules... it will be mush in 2 years.
Perhaps you should point that out to your client?
If there so ignorant to insist you carry on, fair enough..
Waste of good firewood, though....
spiral
Why do you all say beech just fire wood when butterfly spalted beech tables or just spalted beech coffee tables are just stunning I am always after spalted beech send some my way
Cheers Mark
mmm it can be beautiful indeed, & for indoor use it works, The poster is suggesting using it outside & even for fence rails.
Personally although it can be amazingly stunning in figure I've always found it to warp a lot & be loved by woodworm.
The trunk featured looks particularly likely to warp as planks I would have thought?
But yes short lengths cut thick ,dried & kilned the planed flat a couple of times. I am sure would be beautiful .
So yes miss shaped, end of life sized beech , is great for Coffee tables & firewood! & bowl turning as well of course. :thumbup1:
Spiral
