Need a bigger saw. Something equivalent to an old stihl 44 but a new Husky.?
Thinking 24" to 28" bar length ? Which is the model to go for and who does the best price.
HI NEWBIE 461 will run 20/25" bar and a 660 25" up mate thanks jon :thumbup:
I've a MS460 that runs a 25" bar with loads of power to spare, but they've been replaced. If you can get one, I'd go there. Should be around the £850 mark if my memory serves me correctly, anything under 20% of the RRP's an ok price.
On an aside, has anyone ever run a 30" bar on a ms460? I've got a tree that it'd be useful for but was wondering if it'd run that ok.
I have a husqvarna 576xp, can't fault it! It lives with a 18" bar but I stick a 24" on when up a tree, doesn't feel like it's struggling at all in my opinion, cracking saw, you could look at a husky 372xp too
Husky equivalent is the 372xp but you can buy a 365 cheaper and there's an easy mod with a dremal that basically makes it in to a 372.
The 365 has to be the strato version though.
I would look at the 576xp as well its a bit heavier but more power.
Modern still equivalent is the 441 and 461.
I have run a 30 inch bar on an 046, it runs ok but of course a little slow and is at the max length the oil pump can handle. I have run a 36 inch bar on the 046, it works, but even slower and I had to fit a high flow rate oil pump for that. Yes, I should use a bigger saw on the really big stuff but I rarely need more than a 25 inch bar and an oil pump was cheaper than a bigger saw :)
