  • Replies 60
Only one for now, I dont have one in green though, so I may have to buy another!
well i have 2 but both in green
but only one is CE marked
i really like cinch although it does work better with 10mm which restricts you to herkulees or honey bee which are basically the same ropes in different colours
it,s a bit sticky with 11mm
and 10 mm does seam a bit thin at first
Edited by bob
I'm going to try out the ART positioner at the get together, If i buy it I'll sell you my isc grab for £15:001_smile:
The cinch is way better than a positioner IMO. I've had a positioner but gave it away when I got the cinch. It works more like a knot and pulley set up, it releases under tension much better, you can do micro adjustments much better, its work on single line so you can girth hitch you lanyard on a stem and use the cinch along the whole lenght in single line set up (the positioner can't do that) and I think its cheaper! And its green!
