Best way to get planks smooth after milling?
jamesd
Depends how much you have to do, how long you want to spend doing it, arm ache, end product and budget. Besides solutions already mentioned - can buy large electric hand planers, not cheap. Makita do a 6 and 12 inch models (around £500 and £1400), mafell do a range 8,10,12 inch (several thousand quid...). These type of units are built like tanks..Picked up a second hand makita 6 inch for less that £150
  • Replies 20
HI i use a 9and a half inch grinder with a backing pad with a rough sanding disc it takes big ridges out ok and width is no problem my planer only takes 12inch width and is a bloody pain as i want wide smooth boards ,anybody in dorset run a wide planer please get in toutch cheers Mark
You need to get some photos of that up here
Sent from my Nexus 7 using Arbtalk mobile app
its on a large skid frame, just had a service so all the guarding to fit. it has four feed rollers so the greenest of wood never jams. the main roller is mounted on a pivot allowing up to 20mm cut in each pass
Love that, great old bit of kit
