  • Replies 66
What dremel and bit is the best for grinding the steel off? I just bought a cheap one for 15 quid off ebay and it is seriously slow. Maybe i have the wrong grinding stone?
What do you guys use?
cheers
Diamond burrs for steel, or grinding stones
Sent using Arbtalk Mobile App
Look for carbide burr in google. If the rotary tool is variable speed turn it up to top speed and don't use much pressure let the tool do the work. Wear good protection as well as they make sharp splinters.
thanks, found these http://www.ebay.co.uk/itm/10-Mix-Tungsten-6mm-Head-Carbide-Burrs-For-Dremel-Rotary-Tool-Drill-Carving-Bit-/111121429075?pt=UK_Home_Garden_PowerTools_SM&hash=item19df5a7253
the rotary tool i bought goes from 10,000 to 35,000 rpm so similar to what the dremel brand tool does
Hi folks,
I'm new to posting but have been reading on here for a while!
On the 365 modification - I have a 1 year old 365xt - do I need to remove the cyclinder completely to get the transfer covers off? is it a T-25 security torx bit?
and can someone post a step by step carb retune guide for after the transfer port limiters have been removed?
Regards,
Gixer1
Hi folks,
Regards,
Gixer1
Go back a page to 18 stoners post #44 . Tells you there . :001_smile:
Thanks for the help but does anyone have an answer for the carb tuning question?
Regards,
Gixer
