  • Replies 23
If i'm right liquid glass is two part acrylic, like an epoxy resin, you mix it up and the spread it over the area, air bubbles will form and to remove this you use a heat lamp which will soften the resin and then you use a float to smooth it out. Best way to get an idea of it is look on youtube.
Jake
Read more
