I need to check if it has a ignition govenor, i thought it did, by the way i do understand all the principles of how a carb works, even the compensator on the carb. I need to speak to my auto tune specialist to see just how it will react with a ported cylinder,
When do you lot shut shop for Christmas? I've snapped the muffler gasket!
She's a beauty spud! What size pipe do you use on the muffler?
15.5mm O/D - just whatever suitable stock I have to hand!
Shutting for Christmas - will keep going until I am finished:thumbup:
No engine mods just bar sproket and chain! I need these:thumbup: but not the bar
He is cutting hemlock(Tsuga heterophylla) in that vid - it is about as dense as noble fir at best. He is also using low pro chain on a narrow kerf bar. And judging by the size of the chips, the chain appears to have been massaged.
Here's a 357 slicing thru it like butter. I've fallen hundreds of them myself, and bucked even more.
Here's one a bit more mature.
What do you mean the chain maybe messaged :confused1:
Massaged he says. It's probably been given a rub down to get it in the mood :thumbup: Lowered rakers would be my guess if the chip is coming off heavy.
