Had Burrells 357Xp in today, one of the first I ported. He said that the saw had a changeable idle and traced it back to fine sawdust in the carb gauze strainer.
Took the oportunity to measure the compression - 200psi - pretty good considering it just had the base gasket removed and a new piston - it has been run hard for 2-3 years and looks it but the pressure/Vac tests were also perfect.....all good:thumbup:
HI STEVE will a ported 461 on a 20" bar see off a 650 on a 20" bar thanks jon :thumbup:
What mix is he running?
  • 1 month later...
Compression is a funny old thing - we are talking secondary compression and not primary (crankcase) compression!
I have had a few engines that have made good compression (150psi+) and severely lacked power, on inspection I have generally found worn piston skirts causing the problem.
I have had other low compression saws I have tried to up the compression on by dumping the base gasket and had a good increase in compression but still low on power output.
The summary to all this is that if your saw is down on compression and/or power then a "quick bodge" isn't possible on a worn piston. The piston needs more than a decent ring to give good power and the skirts being a good fit do more than stop piston slap and aid low down torque and ultimate power!
Been having a couple of non oiling issues with my little 150. Stripped and cleaned the bar and oiler the other day but it was still sporadic. Today I drained and rinsed the tank with a bit of 2 stroke mix and it seems to have finally flushed out the crud that was in there. Result.
I also decided, after trawling through a thread on the TH about modding the 150t, to drill the muffle with a 10mm hole.
Jeez, it sounds like a stonker with bags of power for such a tinny saw. Cant wait to use it tomorrow.
Anyone else who has done this? MattyF? Did you richen the mix a little bit when you did yours? I will do a few test cuts tomorrow and then check the plug for colour but just wondering if I should richen it up a bit before hand?
Any advice appreciated.
It is always easier to start rich and work down than to start lean and seize the engine although that probably won't happen!
Mine didn't need adjustment with a 9mm hole Rich Rule, but as Spud says.. I would tweek it up 1/4 turn on the H screw, then fine tune the L & H from there.
