Hiccup with Pickup
aspenarb
Our transit tipper had some chip on, when the guys went to tip off the tipper went up about a foot and suddenly dropped like a stone. The ram had pushed its way out of its frame and mangled all the bracing .It always struggles to tip because the greedy boards take most of the load up behind the cab rather than evenly across the bed as it would have been designed for. Could have been nasty. Went to get it off and all the bushes are seized solid so had to attack it with the hot spanner. Got the frame in on the bench for rebuild so I will beef it up and post some pickys of it.
Bob
http://arbtalk.co.uk/forum/attachment.php?attachmentid=142643&stc=1&d=1386615888
http://arbtalk.co.uk/forum/attachment.php?attachmentid=142644&stc=1&d=1386615940
http://arbtalk.co.uk/forum/attachment.php?attachmentid=142645&stc=1&d=1386616003
http://arbtalk.co.uk/forum/attachment.php?attachmentid=142646&stc=1&d=1386616082
http://arbtalk.co.uk/forum/attachment.php?attachmentid=142647&stc=1&d=1386616140
Edited by aspenarb
Harsh is/was the best known cantilever design.
Claimed to prevent the tipped bodywork twisting.
My only comment on those photos as posted is that in either case the ram is very far back.
To get a steeper tipping angle I appreciate.
But putting absolutly tremendous strains on the bodywork and tipping mechanism.
A longer, thinner ram furthur forward would achieve the same with much less stress.
But harder to house within the confines of a van type chassis.
Is that the normal ram position for a transit sort of cantiliver action? mine just goes up 4 sections
That is a much better set than the contraption on this transit, that set up is under an old tipper body in the yard so if this gives anymore grief I will swap it over. All these rams have to go this far back because ford have fitted the cross member in the way of the proper location , seems like a fundamental mistake.
Anyway straightened out the frame spun up some new steel bushes twice the size of the originals, some new pins and brass bearings on the lathe welded it back together and shoved it all back in . All good again.
Bob
http://arbtalk.co.uk/forum/attachment.php?attachmentid=143064&stc=1&d=1386889936
http://arbtalk.co.uk/forum/attachment.php?attachmentid=143065&stc=1&d=1386890147
http://arbtalk.co.uk/forum/attachment.php?attachmentid=143066&stc=1&d=1386890225
http://arbtalk.co.uk/forum/attachment.php?attachmentid=143067&stc=1&d=1386890319
http://arbtalk.co.uk/forum/attachment.php?attachmentid=143068&stc=1&d=1386890388
