Marshall 802 Tractor - opinions?
  • Replies 28
Marshall were layland re branded, good tracror, basic and easy too live with, often overlooked.
I have s 71 layland 384 running s splitter and it never misses a beat, dead simple old skool technology.
Parts are readily available.
Marshal = BMC ie leyland nuffield etc top tractors often cheap as overlooked parts arnt too bad to find
and you can bolt in a big 6 fairly easy for an instant 100hp untouched. 2wd then swap the final drive+ tall rear tyres for a real 40mph if your brave enough!!! In the the east Lancs hill's 6cylinder nuff leylands and marshalls where the contractors weapon of choice when I was growing up!! Quite frankly showing up the modern tractors of the time. Thumbs up from me!
Dare I suggest there would be a bit of collector interest in the Marshall marque.?
Certainly soundly if unimaginatively engineered.
The later/last ones were actually rebadged Steyr's if I recall.(Or was there some other connection)
Again properly engineered kit.
Cab off for a clutch should not be an issue, once every 20/25/30 years.
