Climbing Wellies
Joe Newton
So I was given my first proper Wellingtonia job today!
Just pulling a few branches away from a house where a car had previously been clobbered.
It was an estimated 100'. I don't know exactly but I had to recrotch to get down!
Thoroughly enjoyed myself (once I'd got my top anchor in) though I found it a bit hairy. I enjoyed my cuppa and ciggie even more at lunch!
The problem I found though was on making my way to my top anchor. None of us are too handy with a throwline, and it must have taken me half an hour to get into the tree from a ladder! I found that the alternating your ropes didn't work too well due to the downward nature of the branches.
Anyone have and handy hints or tips I might be missing? I ended up throwing a rope over an above branch and sinching it tight with a running bowline, then just progressing using alternating single lines.
I got lucky in the second one with a flukey big shot attempt and managed to isolate a decent branch reasonably high.
Haha Old Mill, I know you like your shinies, I can't rightly judge as I'm somewhat similar, but theres no way I'm shelling out for a RopeKnight when I can usually miss just as accurately with a £10 throw bag!
I need to practice with my throwline, and a big shot, but it ain't easy when you're under the gun.
Even if it takes the same amount of time faffing with a big shot as it does to climb my way up I think my employer feels more productive to see me make a very slow progress past the first few branches than to see me spend 20 minutes with a throwline and then quick progress into the tree, if that makes sense...
learn how to use a throw line :confused1: ? haha if that fails just chuck your rope over the branches and haul ya way up ddrt mate, no point in fluffing around with that system , sounds tedious.
personally i would set a line up top and srt it and if i needed to climb higher then my ascent line just ddrt it from there :thumbup:
I'm with you there mate 90 percent of the trees in this country are just as quick to use a ladder and rope on!
Sent using Arbtalk Mobile App
