Cherry josh ?? Make sure you seal the ends if it is ... I was gutted when I looked through a stack I had milled and pegged up a few months back this week ,most of it was split! Didn't think that would happen as it had been on a pile for two years so if its green it will be far worse.
some ash I done yesterday ps I did not cut the side someone else started the job and cut the sides as the only had a ms660 with a 36inch bar and had to cut the sides to mill
I have a bigger mill :thumbup1:
the heart wood was so nice I had to post pics
I installed a bench I made at the Village Hall today. see attached vid.
Made from Oak felled on a nearby estate, would have gone for firewood, I hope this is a better use! Cheers, Pup. :001_cool:
That is very clever, I like it a lot :thumbup1:
Do you have any side-on pictures from earlier in the construction which show how the back legs are done?
Alec
That's some really nice colour for ash. Doesn't seem to have lost much from the trimming up (and saved your chain a bit :001_smile:)
Alec
Love that, very clever use of the shape:thumbup:
Like that a lot pup, name suits it, it's the sort of thing David Nash would make and put a long winded explanation of in fitting organic form complimenting its surroundings and put a big££££On it. Bet the client was caped about it :thumbup:
Alec
Thank you Alec, you're comment is very kind. I'm going to try and post a side on picture, having a little trouble with the tech at the minute.
Thank you Wisewood, great feedback. I was a bit shy to post for fear of being shot down, your comment is appreciated.
