  • Replies 123
You're wrong Johny.
It's called a 'ton bag', it must have a ton in it.
I think a metric tonne is the same as an old ton as well.
It's just a term used by younger people.
Anyway, lets move on to price.
It's fifty quid a load, always has been, always will be.
You're wrong Johny.
Builders materials are sold by volume not weight because of the varying moisture content from day to day conditions, isn't wood sold on the same basis ?
Tsk tsk gentlemen.
(i) Sand and aggregate is sold by the tonne ex builders merchants, the moisture content makes very little difference due to the free draining nature of these products.
(ii) About 1.5 to 2.0 tonne per m3, hence the "odd" volume of a builders tonne bag.
(iii) mass concrete being 2.4 t/m3
An imperial ton is 2240lbs being 20cwt by 8 stone by 14lbs in a stone
A tonne is 1000kg by near nuff 2.2lbs = 2200lbs i.e. 20lbs "light"
Or was sometimes referred to as a "short" ton.
The intersnot will provide more exact comparisons and bulk densities.
cheers
marcus
Tsk tsk gentlemen.
cheers
marcus
god you must be bored or single :001_rolleyes::laugh1:
