  • Replies 30
Popular Days
Is that what the line is cutting across the deck in the first pic?
Mighty fine work sir, mighty fine.
Big T tip is to take your time and if you get residue on the flags clean it off asap.
re pointing of slabs as most of you do make it damp then spread into joints and trowel in with a bucket handle.
now the debate i lay slabs on sharp sand cement mix. others say lay a hard base wit either cement dobs i hate or a thin mix of sharp sand cement. i think its a waste of time putting down a hard base if using harp sand cement mix thick enough do not lay many slabs but thats the way i lay them any better idears to my way. be good to know from those who do it a lot.
I always lay minimum 100mm type1 base, and allow 2" bed on average thickness slab, I use coarse sharp sand. We call it washed river grit round here. I point in a mix of soft and leighton sharp(king of sands). I think the only way you can not lay a base is if you lay in minmum 100mm bed. This can makes slabs float when laying next to them and is waste of cement and energy knocking it up. I always lay a solid bed of mortar.
