Thanks for taking the shots of the base James.
Big heap of timber, fine job
no worries david, any ideas of what might have been causing the decay. no signs of fruiting bodies on the floor of anywhere on the stem.
would this have been one of or maybe the reason it finally died?
forgot to say its 136/ 140 yrs old
  • Replies 147
I think it looks like the kind of dysfunction associated with Armillaria.
Shame there's no history of fruiting been noted over the last few years.
Do we take it there hasn't been any mycelial sheets noted under the bark so far, is that right?
Its been surveyed by a very professional company on a regular basis the owner doesnt no why its died though so i gather there hasnt been any history of fruiting bodies found. I havent peeled back any bark but there hasnt been any sign of anything unusal it patches of bark that got removed while lowering etc.
Well done, good job. Did you bring the job in on time (ie make enough money)
Yep worked out perfectly in the end i was worried on sunday when i went to go set up the ropes ready for the monday start, it was then i finally desided on a crane
Do you work out the weight and length of each section of trunk so determining we're to cut so that the crane is working within SWL or is a guestamate using your experience from previous jobs bearing in mind different weights for different trees?
