Just wondering if anybody has used the Clipex fencing system
Clipex Fence Solution | McVeigh Parker
Got about 150m of fence to replace with no machinery access and the slope is very steep so got to hump the gear in and do the job manually.
Clipex seems to tick the boxes as far as ease of installation and also seems relatively easy to move it at a later date which is a definite posibility in 3 or 4 years time.
Grateful for thoughts on Clipex or suggestions for an alternative approach to the job.
Its very good, very condensed material wise compared to using timber and very easy to go up. whether its that much quicker than conventional stock fencing in good conditions im not sure. You don't need many tools and as long as you can drive the strainers in the inters are easy. You will need a gripple tool though and I would specify the g-pac 4mm and not the 3mm that they come with as due to the way the strainers work there is a lot of pressure on them and I have had a couple break. I mentioned this to McVeigh advising they weren't man enough. Price wise its very comparible with hc4 timber but gets expensive when you have a lot of direction changes and need a lot of strainers (nearly £70 for a two way strainer). They say that the beefy posts are good enough for direction changes up to 30 degress but they are not and the fence will pull them in! I have found that gently curving the lines works better and spreading the bend across a few posts, not something I would do normally though. Try some and see how you get on!
Cheers Spikey
Yes a bit more reading today and have to agree re the strainers, but luckily its just a straight-ish run with only a gentle curve along the way.
  • 3 weeks later...
