Beginners climbing guide, hints, tips and general climbing techniques
I just use pulleysaver to do same thing. That xtc cant self tend that well through zigzag, unless you've got a lot of rope below it, or a weight tied onto it lol.
The pole saw packed up today (too much double extension use) during cutting a fair substantial oak limb. I didn't have my climbing kit so used a sling as a harness and made a three knot system with an old pulling rope to get up there and finish it off.
Two morals of the story.
1. Don't climb on shit, old, un-LOLLERed rope.
2. Learn and remember the basics, because you never know when you might need to use them!
I've used a sling as a harness quite a bit. Around the arse and each end back over your hips, grab a bight between your legs, tie the three bights together with your knot of choice... simple, lightweight, sturdy, and accentuates your package nicely if you are wearing tight trousers.
^^ Yep, that kind of thing, but I've only ever used skinny little mountaineering slings that really bite into your buttocks. Wildly uncomfortable. A decent quick fix for abseiling over rocky ground, but I wouldn't want to be hanging around in a tree all day in one. You'd probably want some nice fat webbing as above.
Or, you know... don't forget to pack your harness.
edit
I've also used an ultra-basic sit harness of just a 60cm sling crossed over, a leg through each loop, and a belay 'biner clipped to where they cross in the middle, above your crotch. Can't recommend.
Edited by peds
What harness would people say is closest to a weaver WLC 560? Bridge & the rings they have)  Would like one but they aren’t CE marked so can’t use one in UK.
  • 2 months later...
Can I ask ideally what's the best length for the friction cord on a hitch climber system
It depend slightly on the core and the knot but I think 60cm ish measure eye to eye is about right
