Beginners climbing guide, hints, tips and general climbing techniques
1 hour ago, SamHulston1 said:
Foot ascender isn’t that for SRT or will it work DRT
I use a Foot Ascender on DRT otherwise I look like a comedy show pulling my fat ass up on a rope.
23 minutes ago, Mark Bolam said:
Same as Saturday night sex then.
Normally with the same amount of crying and a couple of blisters
Hi, I was just wondering if there is a way I can make my own adjustable lanyard for when blocking down stems with just rope, karabiners, fisherman's ted into them and friction cord? Or is this not possible?
Currently I climb on 2 lines, one long rope and one shorter for positioning. But when blocking down stems and both are choked round the tree and going to my bridge its not the most stable.
Edited by J7G7
Yep. Lots of folk use rope instead of a wire core flipline. You can just whack a prussock on it or a pulley and friction cord. You'll be much better with it on your side d's
Thanks, and then you would add a pulley for self tending if you wanted too? I guess also how would I make it, I've tried using the rope, tied fishersmens into the karabiners on both ends but then you add the friction cord and when you try to adjust you're just left with a big circle, you know? like on a petzl grilling lets say, the rope runs straight through the cam when adjusting slack and tension.
