9 minutes ago, Mick Dempsey said:
Yes speed control right next to the hopper. Don’t think the stress control is adjustable, why would you?
You can set it on jensens so it doesnt take in so much and knock the revs down so far.... so takes a bit and kicks in and revs stay up....
Yes I totally agree, with the Jensen, you slow the rollers in feed speed, so then the flywheel does not slow as much and there for you get a more general feed. Rather than the  the stop start like you had in your vid
cheers
Sure you can slow the feed rollers, then the flywheel won’t slow and the no stress won’t kick in, but why would you?
Edited by Mick Dempsey
I'll put it like this, if you shove as much in your mouth as it will take. You then have to try and chew it and then swallow, maybe have a sip of wine to wash it down. Then have breath of air before you shove as much as you can in again.
or if you put a bit in and chew and keep chewing while still feeding your mouth have a sip feed a bit more, chew a bit, feed a bit. Etc.   It’s all about the sweet spot, in your feeding habits.
the same goes for a chipper..?.  Wmmv...?
