2 hours ago, Mick Dempsey said:
Well spotted, 572, maybe just long enough, but I bolloxed it up coming in from the shed side.
Had fibre pull out of the felled butt, which would likely have got me  told off if I was a commercial faller.
If you were a commercial feller the cut would have been at ground level and the butt a bit longer.
Have we got a "trees eating things" thread? I had a quick look, couldn't find anything.
Took the tops off two sycamorewhile the fellas chipped, ringed, and split a windblown multistem cyprus, a day and a half. Then went for a drive over the hill to find some windblown spruce and birch. Just rings, no chips or splits.
New jeep is earning her keep.
First proper hedge job with the Makita UH006, very very pleased with this hedger, its very light. Used one small 2.5Ah battery.
Privet, she wanted it reduced hard as it was taller than her, and thined in width, so the brown was unavoidable - it'll grow back. Removed the dead stem.
IMG_20250426_220213.thumb.jpg.eb4872489380434984a8fd5ea24c2e7e.jpgIMG_20250426_220405.thumb.jpg.043d1c540f0d5090cb110c46e4e021c3.jpg
However I did hit the metal gate post and put a tiny ding on the new blade 😭
Pebble gardens are a real pain to clear up if you forget the leaf blower! I dont usually take my own as the other guys will have one. Going back to blow it.
Then an oak stump to cut up. The pictures I saw made it look small but this was big, over a meter dia at base and several meters long.
Im told it blew down in december, so as far as windblown go, quite disapointing, no tension left and the rootplate just sat there.
Oct it looked like this on streetview. Ivy covered, pollarded monster.Screenshot_2025-04-26-22-46-35-624_com.google.android_apps_maps.thumb.png.4126dd72982d08cea0989db596a80534.png
Edited by kram
Yes, a pattern parts clone of the 372xp that was £152 new from China, its done a reasonable amount of work.
It gave me some problems yesterday but thats my own fault - I have had it apart before and must not have tightened up properly. Anyway the exhaust started to fall off, two small bracket bolts gone. Doesnt run properly with it loose, had to find screwfix for some long arm hex keys. Ofcourse the gasket was ruined so it kept vibrating loose.
Would a genuine one have had the same problem, yes, 100% user error on my part. I may treat it to a meteor cylinder and piston kit upgrade soon.
And there's the rub.
A guy I used to work with got one (Blue Thunder, it featured on this thread at one time).
Straight away he put a decent bar and chain on it. Then it wasn't too comfortable to use for any length of time so he swopped out the AV for Stihl ones, then chain brake, then something else and something else. In between all this it had a regular slot at the saw mechanic to be tuned up because it wouldn't hold. Last I heard it was going to get a new carb or whatever but the mechanic said no, don't bring it back again.
It's an ornament now and can't have been much cheaper in the long run than an actual Stihl.
Don't mean to be negative kram, all the best with yours!
You dont buy one if your paying mechanic rates, you have to be competent at saws yourself. Mine arrived with a bad fuel vent, they sent a new tank. A real pain getting the new theottle cable in but that is the Husqy design, took a long time to work out!
The niggle is the choke lever pops out its hole on the carb, but easy enough to do with a scrench. The cover comes off easily.
