26 minutes ago, AHPP said:
I was going to say no way the little bracket winch moved those but apparently it did! What a useful thing.
Yes, impressive performance.
It’s got a little creep under tension which is annoying.
Edited by Mick Dempsey
No I don’t mean Eggsarascal, I mean it lets out a bit of cable gradually under strain.
  • Haha 3
Or hang a weight mid line to keep tension on if you have to walk away for any period of time.
Aware less convenient than the thing working perfectly but helps with visual check for tension, movement etc.
Does it creep faster with more tension on?
Edited by AHPP
We’re a two man outfit so I trust the groundy to give it a blip every 30 seconds to keep tension on.
It is in the winch itself as the motor has been refurbished and even replaced when that didn’t cure it. Though I made them send it back and put the old one on once we established the source of the problem.
Finding a competent engineer, familiar with the workings of these things is the issue.
Thinking about it, it can’t be as simple as a turning a shaft inside the drum to turn the unit (in the same way as a motor turns a feed roller on a chipper) because that couldn’t generate the force that the drum produces.
Doubt it has a reduction planetary gearbox, just relying on pure low capacity hydraulic grunt from pressure at 210-300 bar.
There's a calculator somewhere, plus it depends if it's a standard pump or a piston type.
Two hoses are in & out, smaller is just case drain back to the tank.
You'd be surprised how simple a lift assist cylinder is on a tractor, but two of those is 3-6 ton depending on model.
