My current "cheapie" pole pruner finally fell apart. I've read a few threads here on manual pole pruners which have lead me to choose between these two.
Fiskars Telescopic Universal Cutter Anvil
P34-27-3MF Tree Pruner & Pole
Two very different mechanisms. The only comment I can make on the Bahco is the telescopic pole tends to loosen during use ( I already have one with a saw blade).
Has anyone got a preference for either mechanism.
  • Replies 20
I think it was David Goss from on here that always plugged the Fiskars . Where has he disappeared to btw ?? :001_smile:
Had wondered the same thing myself.
Personally I use the AUS pruners because they can be used live line. Plus you can get heaps of extension on them just by adding poles.
Go for the Bahco, can get to any height required with the use of more poles on the end, good build quality. Have used that Fiskars and was ok for very small branches, but anything of any size and it was horrible to use and ended up breaking after a short use. Also cant hook the branches due to the way the cutter head is positioned.
Ross.
