  • Replies 37
I only have a 30" bar on it , and new chain , I was thinking that the bar maybe bent s_ _ t, where's a good place to buy new bar and chain on line.
thanks for your help ,
and yes I do the same as said above with all my saw's , end of a working day clean and file them.
My hand sharpening is just about passable. If I start making banana cuts its normally cos I have sharpenened the teeth too much on one side. The cure for me was the £20 lidls bench grinder. Used gently after about 6 hand sharpens works for me, they are in stock today normally sell out quick as the stone is about £12 on it own. Bench grinders can eat chains but I am more precision engineer than wood man and an electric grinder in my hands is better than my hands if that makes sense.
I have a diamond file to put that finest of edges on, but I do pick my jobs for it. It leaves a superb edge but three isn't a lot of point going to the extra effort if the timber isn't super clean.
Not sure about the tag of "Chainsaw Geek" .....well perhaps:blushing:
The Banana cut is generally down to the rails opening up or wearing unevenly - both mean the cutters on one side of the chain get worn down faster and need more sharpening meaning further sharpening and uneven cutting.
Seen some classics in my time:001_rolleyes:
Put the bar in a bench vice and put a straight edge at 90 deg on the top of the bar - it should lay flat across it. There should also be negligible chain roll when a NEW chain is pushed side to side with the drive links in the bar.
Only got to this level of geekness on timed cuts on tuned saws:thumbup:
No Huck, every sharpen.
Workshop only, I don't turn the bar 'in the field'.
I don't sharpen in the workshop, only "in the field".
