I'm looking into my first rigging kit and would like some thoughts on my short list.
Marlow Doublebraid 12mm x 50m
Yale 16mm Whoopie Sling
ISC Small Cast Pulley
Stein Portawrap RC1000
English Braids 16mm x 5m Sling
Would this all sound like a sound kit for lighter rigging duties, or should I look at a bollard:confused1:
  • Replies 471
Sounds good but I'd always go for a bollard if money permits. Maybe a swing cheek rigging pulley too. So you can rig off centre if required.
As Ian said go for an rc2001 if you can as it's so much more friendly to use.
You could get a pinto rig and a few slings for a redirect and I'd always go for a spliced line if it's an option as makes light notless rigging so much quicker.
What would be the advantages of a bollard over one of these?
59766b16b4a55_180x180xcl-a65-rcp10007E1.jpg.pagespeed_ic.7CgrpNGB8i.jpg.e8f2a4255cbad84a9c75fbb412d64f98.jpg
There we'll still be a small amount of slack in that system. A fixed bollard makes for much smoother and predictable rigging.
Depends on your work. We get on fine with a port a wrap type thing most of the time. On big dismantles a fixed bollard is a definite advantage. If the person on the ropes isn't switched on it won't make a huge difference though :)
If your only running 12mm double braid it will be fine, personally I would start at 14mm for rigging lines unless your intending to use it for only light rigging.
Slack issues would only become a problem with big lumps that 12mm would be killed on IMO so the 2001 is not a bad choice ,You can still get a lot of slack out the system once your familiar with it and I found 2001 more superior than ports wrap style devices for lowering with ease of use ability to hold and run wood.
I use a 3001 and and its a heavy bit of kit,comes in to its own with big rigging though and a porter wrap for light stuff.
As matty said, the 2001 gives you the option of cutting in a mount seat which is better for blocking down even if this is a future thing and it's kinder to your ropes with a bigger bend radius.
As the mps say it's helping future proof yourself.
Nowt wrong with a floating capstan, still use an old 1 in the 12mm kit for pruning works or for a 2nd tail line but non of my lads would pick it out of choice.
