Hi Peeps,
Considering purchasing myself a new set of wheels. Have seen online a decent looking Honda Civic 1.6 VTEC Sport. Was keen on going out to give a once over, but got put off when I rang the dealer to check a few details and was informed that the mileage was 115k.
The car is almost exactly 7 yr old on a 54 plate. 115K on 7 yr old car seems a bit steep, it works out on avg. 16.5K per annum. I don't know the history, but the dealer claims it has a FSH, although he could'nt confirm if they had all been done by a Honda garage.
Question is, just how reliable would a high miler Honda be? Are they bomb proof if its been looked after properly, or is it best to avoid............?
Any anecdotal stories, pros & cons, that you can advise to help me decide if its worth pursuing further would be gratefully received.
Many thanks.
Tricky
Hondas are a renowned for there reliability, but being that much mileage would be look with caution, a test drive is always good any strange noises don't bother, make sure the engine temp gets up and then listen, also the usual rust on chassis and under body is good. Depends on previous owners driving aswell if it was ragged like stink it will sound rough and not worth it, it was dRiven by a granny then it will be a slow engine, I like Hondas mowers and quads but don't like there cars.
we have a 2003 honda civic 1.6l It's being very reliable.But there again all jap stuff seems to be reliable. Would buy another. Although, milage is a bit high on the one your looking at
With any used car or truck I always take the vehicle to my mechanic. I also make sure that my mechanic is not to chummy with the dealership the vehicle came from. If it came from a private owner same thing. Honda's over here when well maintained last for 100'000 plus Miles and still going strong. Normal maintenance is the key. Also we have a service called Car Fax over here and it can provide for a small charge the history of the car for inspection.
easy-lift guy
Mileage is a bit on the high side, try not to fall in love with it but look out for a lower mileage one. You might think they are difficult to find, but you will find loads just after you bought this one!
There a good motor and reliable, but can give a bit of bother when the mile get up a bit. Think there chain driven and they are know to snap the odd one.
As said I would be looking something a bit fresher.
Sent from my aye phone using Tapatalk
