Bargain me thinks :001_smile:
Had it done whilst away skiing this week and I'm chuffed to bits with it. Had the box built using the old tipping gear motor and ram.
There is still a toolbox to build in and a clean up.
Should look the dogs when sign written.
I haven't weighed it off after build but we did weigh off with the old back on which was 2600kg empty. It must be a sight lighter as it is sat right up on the suspension.
  • Replies 89
Reet Smart Mr Lofthouse!
I was recently told that in order to clean up oxidized surfaces like hot dip galv and alloy - try kettle descaler! Need a fair bit on something that size tho!
Very,very smart Dean!!!!!!
Do you think you will get any chip being held in by the centre box sections???
Would it be worth lining it with thin ply or smooth ally sheet????, this would also help prevent dents showing on the out side.
Read more
