Nice.......wonder why it wasn't spinning the chain, muffler was also held on by just the lower support bracket screws....no inner ones!
Bonus to it though Spud, it looks pretty clean for ya for a change, or have you already given it a bath before you took the pic?! [emoji23]
One for RobD thread.
  • 4 weeks later...
14 hours ago, spudulike said:
The location of the installation of light bulbs must be large enough to withstand the ability to withstand 10 times the drive weight.
Really?
It's the way to enlightenment grasshopper
Really?
Absolutely ! Cant see it any other way.
Well.....I thought I would read the instructions to my replacement security light.....typically, after fitting it.
I am glad I fitted it as described!!!!
The rest of the instructions were equally useful!!!
Got a funny one - 346 xpg older model. Wont rev up beyond about 12k, even with the bar off only makes 12.5/13k ( no sign of a limited coil kicking in). I have cleaned and changed carb internals, then replaced the carb with a new one, changed ignition coil and checked flywheel key, all ok. Replaced fuel filter, spark plug, fuel line appears nice and rubbery but havent changed. Impulse line is creating vac/pressure, but not visually inspected it. checked piston (appears in good order with good looking piston ring, no scoring).
Havent done a vac test as ain't really displaying symptoms of an air leak but probably what's next unless someone has any better ideas?
Thanks advance
Thanks advance
Is the throttle rod plastic end worn ?
my gad sir! that would be a sweet fix. will check, but think from memory it looked like the butterfly was opening right up
